1. aha's Avatar
    Has anyone gotten Google Assistant on their S7 Edge yet?
    05-15-2017 07:47 PM
  2. ticketbabe2's Avatar
    Yes, just havent used it much..does a lot of things, but doesnt always wake up with voice, then have to hold home button. Sounds cool
    05-15-2017 07:53 PM
  3. aha's Avatar
    How do I know I get it or not? My google app is at 7.1.29.21, but can't find the option to enable Google Assistant in settings.
    05-15-2017 08:36 PM
  4. Fit24's Avatar
    I've had Google Assistant for a few weeks now. I use it frequently.
    05-15-2017 09:34 PM
  5. Fit24's Avatar
    To check if your phone has Google Assistant long press the home button. A page will pop up saying, "Hi, how can I help."
    Attached Thumbnails Google Assistant on S7 Edge?-47597.jpg ย
    05-15-2017 09:47 PM
  6. aha's Avatar
    I definitely don't have that... so I guess I have to rely on Rogers to push the update over, which could be in months.
    05-15-2017 10:07 PM
  7. Mattgrossman's Avatar
    I'm on Rogers and I have it. I use it daily when I'm driving. "OK Google, navigate me home" "OK Google, open Spotify" you can call people, send text msgs. I have had it for about a month now.
    05-16-2017 04:18 AM
  8. talberry's Avatar
    Still waiting for my update too. Its been ages!
    05-16-2017 04:36 AM
  9. Leedsboi86's Avatar
    I have OK Google, where I say "OK Google" and able to search things and get my phone to launch apps etc, but when I press and hold the home button it's still showing as Google Now with no option in settings for assistant
    Do we just have to sit and wait for the long hold press to change to Google Assistant?
    OK Google is pretty decent though, set up my voice with it so any screen I am on I can ask it to launch apps and tell me whats in my diary for today etc.
    Any idea when we will see Google Assistant in UK?
    05-16-2017 05:43 AM
  10. anon(10053053)'s Avatar
    Turn your system default language to English(US) and tap and hold home button while connected to internet. You will get Google Assistant. Later you may change back to any other language, your Assistant will stay.
    05-16-2017 07:11 AM
  11. aha's Avatar
    I can do that too, I believe that's always there in Google Now.
    I think the difference between Google Assistance and Okay Google is, Google Assistant understands context. So you may ask ask about a movie, then ask about who stars in it, and then get the showtime, then get the nearest theatre, all without repeating the movie name.
    But again, I have never tried it so don't know how far they have improved Google Assistant in that regard.
    Am I right about this?
    ticketbabe2 likes this.
    05-16-2017 01:04 PM
  12. aha's Avatar
    You are right! I tried it and it worked. ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    05-16-2017 01:09 PM
  13. talberry's Avatar
    Tht worked for me too! Thank you so much!
    05-16-2017 07:02 PM
  14. ticketbabe2's Avatar
    For some reason, Google Assistant stops working often..the microphone doesn't work (S7 E). Restart doesnt work. Do i need to uninstall S Voice? They've both worked before. Dont know what keeps changing.
    05-18-2017 10:46 AM
  15. Fit24's Avatar
    Yes you are correct.
    05-18-2017 02:27 PM
  16. Fit24's Avatar
    I have S voice and Google Assistant and haven't had any problems with either one. What language are you using?
    05-18-2017 02:38 PM
  17. ticketbabe2's Avatar
    English..never changed it..I saw that recommendation.
    05-18-2017 04:46 PM
  18. Mirest's Avatar
    I have this issue too. There is another thread on the forum about this but no responses there as well. For me it's not just Assistant but the actual Google App that stops working simultaneously.
    05-18-2017 10:48 PM
  19. aha's Avatar
    I think I have the same problem... or a similar one.
    I have to retrain voice model often because from time to time, maybe once a week, Okay google doesn't get triggered by my voice anymore. Especially in my car or when the headphone is one.
    Maybe the voice model trained over the phone's microphone has a different signature than recorded in a car or through the microphone on the headphone?
    07-08-2017 11:23 PM
  1. Replies: 1
    Last Post: 05-16-2017, 07:28 AM
  2. how do I get my S7 edge to stop unlocking when the battery gets low
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-16-2017, 01:42 AM
  3. why i can't installed Fiacebook on my phone
    Last Post: 05-16-2017, 01:27 AM
  4. Replies: 1
    Last Post: 05-15-2017, 07:20 PM
  5. Replies: 0
    Last Post: 05-15-2017, 06:08 PM
