1. blessedred's Avatar
    Recently I put my phone in some running water to clean it off a bit and as of right now I can't charge it. I've never had any noticeable water damage before this and I haven't dropped my phone in a long while. Did the water ceiling break or could this be a bug? Any advice would help.
    05-16-2017 06:34 PM
  2. Dngrsone's Avatar
    You might try tossing it into a Ziploc with some dry rice and let it dehumidify for a while.
    05-16-2017 06:47 PM
  3. BruceFlea478's Avatar
    If there's any moisture at all in the charging port, it will not charge until it is completely dry. Otherwise, it will short out and you will have a ruined phone. Give it some time, I'm sure it will be fine after a while.
    05-16-2017 08:35 PM
  4. LineKill's Avatar
    It normally takes a day or so to fully dry out.
    05-17-2017 09:10 AM
  1. Replies: 1
    Last Post: 05-17-2017, 04:57 PM
  2. QC 3.0 charger doesn't fast charge, but QC 2.0 does?
    By Misterb in forum Samsung Galaxy S8 & S8+
    Last Post: 05-16-2017, 11:50 PM
  3. Replies: 1
    Last Post: 05-16-2017, 10:02 PM
  4. Replies: 1
    Last Post: 05-16-2017, 06:39 PM
  5. Replies: 0
    Last Post: 05-16-2017, 06:11 PM
