1. ayyembee's Avatar
    I upgraded from an S7 edge to S8+ on Verizon. I'm having issues transferring my saved wifi settings (networks, passwords etc) from the 7 to the 8. I used smart switch to transfer everything and had no problems except with wifi. In the smart switch app, it says that everything is transferred when I transfer "settings" but none of my networks are there when I look. I originally thought this was an issue with my s8, so I had verizon send a replacement. Im playing with both s8's and i was able to transfer networks I added again with no issues, so I've figured it's an issue with the 7. However, I'm not sure how to work around it. Does anyone have any suggestions or maybe went through this yourself. Please help if possible. Thank you!
    05-17-2017 09:22 PM
  1. How can I change camera processing settings?
    Last Post: 05-18-2017, 06:10 PM
  2. Verizon Galaxy S8 New to Android, Sync with my Jeep help
    By MercenaryOne in forum Samsung Galaxy S8 & S8+
    Last Post: 05-18-2017, 05:17 PM
  3. Replies: 1
    Last Post: 05-17-2017, 10:40 PM
  4. Replies: 1
    Last Post: 05-17-2017, 06:49 PM
  5. wifi problem s8+
    Last Post: 05-17-2017, 04:14 PM
