1. liquid_core's Avatar
    Hi, on my S7 Edge, the Data usage warning option (NOT the data usage limit) is greyed out and I cannot seem to enable it.
    I was just wondering whether anybody else has encountered the same problem before?
    I am on G935F, Nougat 7.0, baseband G935FXXU1DQD7.
    Thanks in advance for your help!
    05-22-2017 06:16 AM
  2. Javier P's Avatar
    Do you have the same problem after switching mobile data on? In some phones these options are not available when WiFi is on.
    05-22-2017 07:20 AM
  3. liquid_core's Avatar
    Hi Javier, yes it remains an issue even when I'm on mobile data with WiFi turned off
    05-22-2017 01:41 PM
  4. Fit24's Avatar
    I am able to adjust the Data usage warning option my S7 Edge; the numerical data warning limit is greyed out but I can still tap the "Data usage warning" and adjust the warning limit.
    05-23-2017 10:28 PM
  1. Best folio/wallet case out there?
    By elfnberry in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 05-25-2017, 08:10 PM
  2. Replies: 1
    Last Post: 05-22-2017, 12:31 PM
  3. Replies: 1
    Last Post: 05-22-2017, 12:29 PM
  4. Locked out
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-22-2017, 08:18 AM
  5. Replies: 1
    Last Post: 05-22-2017, 05:26 AM
