1. Ghost5772712's Avatar
    Every time I try installing an app that has some permissions that is needed to be granted from the accessibility option in settings, my s7 edge shows a message that says "because an app is obscuring your permission request, settings can't verify your response". I tried safe mode and nothing happened. I tried instantly again after coming out from safe mode and it seemed to work but if I turn it off and on again.. it shows the same message. Is there any solution for it?
    I'm using android 7.0 btw
    05-25-2017 10:55 PM
  2. Tim1954's Avatar
    Is this one particular app or all apps?
    I generally start with cache partition wipe, especially after big updates like Nougat... Try that and see if that works..
    05-26-2017 03:37 AM
  1. Replies: 31
    Last Post: 06-06-2017, 10:48 AM
  2. Replies: 0
    Last Post: 05-25-2017, 09:55 PM
  3. Replies: 0
    Last Post: 05-25-2017, 09:40 PM
  4. Can't connect when Dialing/calling from contact list
    Last Post: 05-25-2017, 08:13 PM
  5. How do I switch contacts from my S3 to my A5
    Last Post: 05-25-2017, 08:00 PM
