1. RU55 MOS's Avatar
    Does the stock/default messaging (sms) app use WiFi?
    My Provider is EE.
    i am currently using ChompSMS because i was told that this uses WiFi as well as normal phone signal.. but i prefer the Standard messaging app, the only reason i stopped using it is because people weren't recieving my messages when i was in a place where i had no signal, maybe there is an option to turn wifi texting on?
    any help would be appreciated, thank you Russ
    05-28-2017 05:57 PM
  2. pappcam's Avatar
    Pretty sure ChompSMS is just regular SMS which uses the regular mobile network. The stock messaging app is also SMS/MMS only.
    If you want messaging apps that use wifi or data then you need WhatsApp and those types of apps.
    dm3ready likes this.
    05-28-2017 08:57 PM
  1. Replies: 4
    Last Post: 05-29-2017, 12:54 PM
  2. How can CM game booster app be deleted?
    Last Post: 05-29-2017, 01:19 AM
  3. Why can't I make phone calls/access contacts on my Galaxy S8+?
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-28-2017, 06:31 PM
  4. Replies: 1
    Last Post: 05-28-2017, 06:05 PM
  5. Replies: 0
    Last Post: 05-28-2017, 05:47 PM
