1. ctsmith84's Avatar
    Hi all,
    Over the last week and a half or so, my S7 Edge has been having a pretty peculiar battery drain issue. I don't know if it's an update related issue or not, but once the battery shows below (from when I've noticed it) around 50%, it will just instantly drain all the way to 0% in a matter of literally a minute or two. And the battery usage doesn't show any app as being a potential culprit.
    Any thoughts on what to try? Did my battery just suddenly get toast? The battery life is great for that first 50%, BTW.
    What makes it even worse is that it continues to drop to 0% even if I'm able to catch it at 15% or so and plug it in. Once it hits 0%, it charges and continues working as normal.
    05-30-2017 05:49 PM
  2. Dngrsone's Avatar
    Unfortunately, it sounds like your battery is bad and needs to be replaced.
    103Softail likes this.
    05-30-2017 05:53 PM
  3. ctsmith84's Avatar
    Kind of what I was thinking. But I am just looking to see if anyone knew of any other solutions first. And also wanted to make sure a new battery would fix it.
    05-30-2017 09:00 PM
  4. msndrstood's Avatar
    If you did an update lately, I'd check your wifi settings. When I updated to the latest security update, it broke my Package Disabler Pro (known issue now) and it reset some of my settings to stock, including that battery sucking culprit, 'wifi scanning'. My battery started dropping 20% per hour, after I unchecked it (my normal setting), it went back to 8-10% per hour. Hope it helps. 😊
    Dngrsone likes this.
    05-31-2017 01:42 PM
  5. Tsepz_GP's Avatar
    Unfortunately this definitely sounds like a Battery that has gone bad, this is exactly how they fail.
    I remember when my Note 4 Battery went bad, it would get to around 20%, and then suddenly go to 5% and die in a matter of minutes.
    How long have you had your S7 Edge?
    06-02-2017 12:19 AM
  6. ctsmith84's Avatar
    I've had it for about 15 months or so. So out of warranty.
    Strange thing is that it seems to do it at exactly 50% every time. And also, the battery life up until that 50% mark has been really great lately, better than in the past for sure. I'm starting to wonder if somehow the % is reading incorrectly???
    06-02-2017 09:44 AM
  7. Bosbouer's Avatar
    Why not try one of the battery recalibration apps to recalibrate the battery.?
    PS I have gone through my playstore library and noted that I chose 3C battery Monitor when my Note 4 was having similar issues.
    06-03-2017 06:57 AM
  8. HBogard's Avatar
    I think you need to replace the battery if the after factory reset the problem remains..
    06-05-2017 06:36 AM
  9. ctsmith84's Avatar
    So I tried one last thing before taking to get the battery replaced. I installed an app called Advanced Battery Calibrator.
    Mainly because I had a feeling the battery percentage wasn't displaying correctly. The manual ways to calibrate it didn't work, but this app apparently did!
    For the second day in a row, the battery drained at a more normal pace.
    Below are the before and afters.
    Attached Thumbnails Galaxy S7 Edge Insta-Drain Issue-screenshot_20170529-094305.jpg   Galaxy S7 Edge Insta-Drain Issue-screenshot_20170606-173212.jpg
    06-06-2017 09:39 PM
  10. troshs's Avatar
    I hate to be the bearer of bad news here, but my mom's did this. Replacing the battery didn't quite work--she got a new phone instead.
    I think sometimes after an OS update or security update, the phone gets wacky with OS settings. I still have my mom's phone and will have to try to experiment with it, but just to add in that sometimes the battery going bad isn't it either. Good luck.
    06-10-2017 11:54 AM
  11. ctsmith84's Avatar
    Mine has been back to normal since I did what I said in my previous post. So I'd recommend anyone seeing this sort of issue to try this out first before replacing a battery or buying a new phone.
    06-12-2017 11:29 AM
  1. UAG Monarch Galaxy S8+ my 2 cents
    By PWFD81 in forum Samsung Galaxy S8 & S8+ Cases & Accessories
    Last Post: 08-07-2017, 02:08 PM
  2. Galaxy s8 root?
    Last Post: 05-30-2017, 04:33 PM
  3. Replies: 1
    Last Post: 05-30-2017, 04:04 PM
  4. Where are the hotkeys on my Samsung Galaxy S6?
    Last Post: 05-30-2017, 03:27 PM
  5. UAG Monarch Galaxy S8+ my 2 cents
    Last Post: 05-30-2017, 03:13 PM
