1. Robert Lindsay's Avatar
    This could go anywhere but as i have a S7E i may as well put it in here.
    I bought an ANker bluetooth speaker. I paired with it just fine and i can play music through the speaker just fine, however i want to stop all other sounds from being sent to the speaker its not nice hearing all the clicking noises and notifications etc while you use other apps on your phone. Can you send audio only to your bluetooth speaker. I use Poweramp for music i have disabled google music.
    06-03-2017 01:16 PM
  2. PJRed2008's Avatar
    It would seem to me that only music would go, especially as you're using a music app. If nothing else, you could turn off system volume when playing music. I would look in Poweramp to see if there is a setting to isolate music, but again, I would see no way those could get thru in the first place. There may be a phone setting to isolate external speakers to music only, otherwise, haven't anything else. Please report back if you find something.
    06-03-2017 01:24 PM
  3. Robert Lindsay's Avatar
    Thanks for your reply. I am able to put my phone into vibrate or silent and this disables the other sounds however when i get a call this still comes through my speaker.
    I went through the setting in Poweramp, there is bluetooth settings but nothing that looks like it does what im looking for.
    06-03-2017 01:46 PM
  4. PJRed2008's Avatar
    Okay, don't think you can do anything about a call as the phone will go to an external source if one is there, it probably thinks its a headset.
    06-03-2017 01:50 PM
  5. Eaglefeet's Avatar
    In the Bluetooth option at the top of the pull down screen if u hold on that and select the settings wheel at the side of it it give options of what audio u want on that device. Just deselect what u don't want and leave audio on
    PJRed2008 likes this.
    06-03-2017 02:26 PM
  6. PJRed2008's Avatar
    Hmm, I don't see that option on my S8+
    And welcome to the forum!
    06-03-2017 02:30 PM
  7. Robert Lindsay's Avatar
    Many thanks for your reply.
    I thought it did not work at first but you actually have to select and hold on the name of the Bluetooth device and not the Bluetooth icon. I found the setting and disabled phone audio, now calls dont go to the speaker which is great. I still get clicking noises like when im using my keypad but that goes off if i put my phone into vibrate or silent. It would be great to disable those sounds too.
    well done were half way there
    06-03-2017 04:02 PM
  8. Eaglefeet's Avatar
    Go into keyboard settings and turn them off. Look for key tap feedback
    06-03-2017 04:04 PM
  9. Robert Lindsay's Avatar
    Yeah thats another option i suppose. I was making lots of typing errors trying to get used to the keyboard, i read someone had the same issue and using the feedback noise and vibration helps, i find it does help me when its enabled. If i dont find another solution i will disable it temporarily while playing music.
    06-03-2017 04:11 PM
  10. wirelessspeakersCA's Avatar
    very same problem not just annoying it seem to cut off my music
    08-09-2017 01:38 AM
  1. I can't stop syncing contacts to my phone
    Last Post: 06-04-2017, 06:47 PM
  2. While videocalling mic is recording audio is iterrupting
    Last Post: 06-03-2017, 01:01 PM
  3. Suggestion - Related to Andriod
    By sanjeetkumardash in forum Ask a Question
    Last Post: 06-03-2017, 12:56 PM
  4. How do i send my games and progress to my tablet.
  5. Why is Android phone having problems connecting to server?
    Last Post: 06-03-2017, 12:50 PM
