1. speedtrip's Avatar
    Like the title says ,
    Dont know if thats a good or bad thing .
    06-03-2017 04:46 PM
  2. PJRed2008's Avatar
    Have you tried to check manually for update on the phone? Unless something was done to the phone you should have gotten the upgrade awhile ago.
    06-03-2017 04:52 PM
  3. speedtrip's Avatar
    She manually checks it often , bought the phone in December
    06-03-2017 04:58 PM
  4. underway99's Avatar
    You should be able to install the update yourself with Samsung 's Smart Switch maintenance utility. If you have a carrier-branded device, they may have included their own maintenance and update utility. Both tools will grab and install the update you need. It will be the same update that you would have received with an OTA update.
    Before you do that though, try clearing the app and system caches (app cache first, then system cache). Your wife's phone may have started the download and been interrupted. If there is a trace of the downloaded update package on the device, that could prevent the phone from grabbing the update on its own.
    06-04-2017 09:31 AM
  5. ssapre's Avatar
    Try to manual search for update after removing the sim. This worked in my case.
    06-05-2017 09:53 AM
  6. speedtrip's Avatar
    I opened the bootloader and it showed an system update and then it crashed , I wiped the cache and still nothing ,
    so a factory reset is in order
    06-05-2017 05:46 PM
  7. speedtrip's Avatar
    i pulled the update off of Smart Switch and her phone worked great for 24 hours then it started looking for service , called verizon and everything came back good on their end so I contacted Samsung they done a remote access and it came back as having a fried circuit , so they are sender her a new phone
    06-10-2017 06:35 PM
  8. underway99's Avatar
    It's always good to hear that people are being taken care of, instead of the "my carrier said ..." experiences.
    06-11-2017 11:11 AM
  1. Replies: 1
    Last Post: 06-05-2017, 06:11 PM
  2. Replies: 1
    Last Post: 06-03-2017, 04:48 PM
  3. why is my lg xpower stuck on firmware update?
    Last Post: 06-03-2017, 04:16 PM
  4. Replies: 1
    Last Post: 06-03-2017, 11:54 AM
  5. Replies: 0
    Last Post: 06-03-2017, 10:25 AM
