1. Puddin46's Avatar
    There's an icon on my galaxy s7 edge that I've never seen before. It kinda looks like a phone mostly inside a box. It's on the status bar.
    06-05-2017 03:24 PM
  2. SpookDroid's Avatar
    WiFi Calling? The phone with the signal bars coming out of it is how it looks on my S8 (and the S7 Edge before), but the rectangle around it is new for me... unless you're in a different carrier and maybe they changed the icons (mine is T-Mobile).
    If you expand the notification bar, do you see it as a notification? If so, if you long-press on that, which app does it take you to?
    Puddin46 likes this.
    06-05-2017 04:55 PM
  3. Puddin46's Avatar
    It's crazy but when I clicked on it nothing happened. What's also weird is that I made a call and when I went to hang up I couldn't. There was a curved arrow that pointed to where the usual hangup icon and it said pull. Crazy. I have Verizon.
    06-05-2017 07:34 PM
  4. SpookDroid's Avatar
    Do you have WiFi-Calling enabled? What happens if you disable it, does the icon go away? Or if you disconnect from WiFi?
    Also, have you received any updates lately? Maybe Verizon updated their dialer app?
    06-06-2017 11:53 AM
  5. underway99's Avatar
    I saw the answer in another thread Remote call & pull??? (credit to Kalvin Kearns). Looks like this was a VZW thing that has to do with linking your phone number and another piece of hardware (like a tablet) with VZW Message+. Here's a link to a discussion on Verizon's community forum. Remote Call
    As I understand it, the remote functionality seems to work through components of Verizon's Message+ messaging client and their Advanced Calling. If you have the Message+ client loaded and configured on multiple devices, (phone, tablet, PC), you get this indication on the Notification Bar when in a call. You'll apparently be able to switch the telephone call to your other connected devices. The way to eliminate it is to disconnect your Verizon Message+ from all of your devices. Alternatively, you can disable Advanced Calling on your phone. But then you'll lose the ability to simultaneously talk and use data, along with losing WiFi calling and HD calling.
    06-06-2017 12:22 PM
  6. Pkmoore71's Avatar
    Does anyone know what app these icons belong to?
    06-07-2017 07:00 PM
  7. SpookDroid's Avatar
    Are they in your notification? They Gallery one is pretty obvious, but unless you're getting 'Story' notifications from the Gallery app, it could be just any app showing media. The other two are most likely a messaging app (the first one looks a lot like the 'warning' notification from the stock messaging app when a message fails to send or download, but the smiling one doesn't ring a bell).
    06-08-2017 11:33 AM
  8. Pkmoore71's Avatar
    They are on my son's phone. He sent me a screenshot of something and I noticed it. He's not allowed to have messaging apps on his phone...it isnt a text notification as I have the same phone. idk.
    06-08-2017 07:54 PM
  9. SpookDroid's Avatar
    Well I'd say it's definitely a messaging app. If it's on a phone, maybe he downloaded a 3rd party texting app that allows you to modify the notification icons (like Textra)? Or if there's an app he installed that has in-game chat or something?
    You can just ask him, too...
    06-09-2017 11:00 AM
  10. Elytherial's Avatar
    help with this unknown icon, please?
    the plus sign with the 2/3rds of around it?...
    thanks in advance!
    07-06-2017 11:34 AM
  11. Javier P's Avatar
    thanks in advance!
    That's the Data Saver icon (settings - data usage - three dots top right).
    07-06-2017 11:41 AM
  12. mark144's Avatar
    Me to... what does it mean, i also have that logo in my phone
    09-01-2017 10:37 AM
  13. chanchan05's Avatar
    Left to right:
    1.) Unsent message
    2.) Messeage notification. Could vary. An SMS app like Textra only sends text messages. It's no different from the in built one other than you can change colors as you want, change icons, etc. You can ask him about it.
    3.) Refers to the gallery app. If you make a screenshot, you get that notification icon.
    09-02-2017 03:27 AM
  1. Replies: 1
    Last Post: 06-05-2017, 09:08 AM
  2. How to change icon image on galaxy s8+?
    Last Post: 06-05-2017, 09:00 AM
  3. i can't find my camera icon
    Last Post: 06-05-2017, 06:49 AM
  4. Icon not showing up why
    Last Post: 06-04-2017, 04:39 PM
  5. icons missing and close all aps option
    By AC Question in forum LG G2
    Last Post: 06-04-2017, 01:38 AM
