1. Darren Kelly2's Avatar
    Hi, I have some real concerns with my S7 edge. I've had it a year and it's been fine up till now.
    Well in recent weeks i have had a keyboard glitch, where if i type something the keyboard types itself and nothing like i've tried to.
    But now it's opening Apps by itself. This afternoon the phone app opened itself and started dialing my recent calls. Then went into my text messages.
    I'm starting to worry that it's got spyware. It as if someone or something else is controlling my phone at random times.
    Any ideas?
    06-06-2017 01:33 PM
  2. anon(238680)'s Avatar
    Welcome to the forum. Poltergeists aside, I think your screen digitizer is going loopy. Do you remember installing an app that may have started it?. I would try clearing your system cache and see if that helps. If not, a factory reset may be the next option.
    06-06-2017 01:41 PM
  3. Darren Kelly2's Avatar
    hey, thank you for the response. Yes this is my first post.. i did find something on the droid guy Galaxy S7 opening SMS on its own, touchscreen not working properly, other issues
    but appears the tests on the touch box work fine. I tried a cache clean yesterday and that didn't work as it came back again. So looking like a complete factory reset! damm i'll lose a lot of my apps and folders/customizations etc.
    06-06-2017 02:00 PM
  4. anon(238680)'s Avatar
    You won't lose any apps you've paid for, they'll be in the Play store once you sign back in, but yeah, lots of stuff to recover. One thing I do, make screenshots of each screen you have, then back them up outside the phone. Helps to remember what you need to redownload.
    06-06-2017 02:30 PM
  1. Replies: 0
    Last Post: 06-06-2017, 01:31 PM
  2. Replies: 2
    Last Post: 06-06-2017, 01:23 PM
  3. Samsung keyboard has unfortunately stopped
    Last Post: 06-06-2017, 01:20 PM
  4. Lost my Calendar widget from All Apps screen
    Last Post: 06-06-2017, 12:48 PM
  5. Replies: 1
    Last Post: 06-06-2017, 12:47 PM
