1. AC Question's Avatar
    Since my Samsung Galaxy s7E updated to android 7.0, I can't find the safety and emergency settings that allows to enable/disable emergency alerts. (In fact the settings menu looks completely different from the universal android settings menu!) Ever since I don't receive severe weather or amber alerts.
    Where were the settings moved to? They're not in the message settings, or sounds settings. Google isn't giving me the answer either, it's frustrating.
    06-12-2017 04:03 PM
  2. anon(238680)'s Avatar
    Settings, Privacy and Emergency, but emergency alerts should be activated by default. You cannot turn amber alerts off. Weather alerts are controlled by your weather app, not emergency settings.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    06-12-2017 04:21 PM
  3. anon(5719825)'s Avatar
    These settings have been moved to the default messaging app. Tap the three dots at the top right when in the messaging app and tap on Emergency alert settings and then Emergency Alerts. You can turn off Amber alerts, Imminent extreme alerts and imminent severe alerts.
    Can't find emergency alerts settings Samsung G s7E-screenshot_20170612-220454.jpg
    Fit24 likes this.
    06-12-2017 11:10 PM
  4. anon(238680)'s Avatar
    Not sure which phone you have, but my S8+ does not have anything close to what you're showing and, as I said above, emergency is under Settings. That was the same on my S7e.
    06-13-2017 10:41 AM
  5. anon(5719825)'s Avatar
    Mine is a S7 Edge. The emergency settings are in the messages app. We are talking about the S7 Edge here. See for yourself in my screen caps. You can even see the edge panel tabs in each screen cap.
    Can't find emergency alerts settings Samsung G s7E-screenshot_20170613-094404.jpgCan't find emergency alerts settings Samsung G s7E-screenshot_20170613-094351.jpgCan't find emergency alerts settings Samsung G s7E-screenshot_20170613-094355.jpg
    Fit24 likes this.
    06-13-2017 10:46 AM
  6. anon(238680)'s Avatar
    Verizon manual for S7e shows Settings, Privacy and Emergency, Emergency. You're correct on Amber alerts, I was thinking Presidential.
    06-13-2017 11:07 AM
  7. anon(5719825)'s Avatar
    I have a T-Mobile S7 Edge on 7.0 and a US Unlocked S7 Edge on 6.0 and there is no Privacy and Emergency under settings.
    06-13-2017 11:09 AM
  8. anon(238680)'s Avatar
    Well, guess I better confine my responses to only Verizon questions in the future.
    06-13-2017 01:16 PM
  9. IAmSixNine's Avatar
    I have a TMO running stock and its in the messaging app, Settings, Emergency Alert Settings
    06-14-2017 11:10 AM
  10. Fit24's Avatar
    Emergency alerts on the AT&T Samsung Galaxy S7 Edge:
    Settings>Applications>Messages>More Settings>Emergency alert settings>Emergency alerts
    06-14-2017 09:40 PM
  11. Iva_LadyDiCaprio98's Avatar
    I have the S8+ and the settings is in the messaging app. I doont know if it has to do with carrier, but I'm on At&t and I found the emergency setting by going to the messaging app > three dots on top right hand corner > settings > emergency alerts settings > emergency alerts and it would be there
    06-15-2017 06:32 AM
  12. anon(238680)'s Avatar
    I don't know if it has to do with carrier,
    Evidently
    06-15-2017 10:59 AM
  1. Gear S3 and Samsung Pay
    By johnmcc0710 in forum Samsung Gear S3
    Last Post: 10-01-2017, 04:05 PM
  2. Galaxy S2 Tab - can't make or receive calls
    By John L4 in forum Ask a Question
    Last Post: 06-13-2017, 01:27 AM
  3. Samsung Galaxy S5 running slow
    Last Post: 06-12-2017, 03:58 PM
  4. Samsung s7 restart loop stuck
    By 9133253848 in forum Samsung Galaxy S7
    Last Post: 06-12-2017, 02:29 PM
  5. Replies: 0
    Last Post: 06-12-2017, 01:31 PM
