So I went ahead and performed the dreaded Factor Data Reset last night and did a restore with Samsung Switch. While all the settings that I would have like to been kept were cleared (and sadly my BKDisabler lists as well), I was able to spend an hour or so getting everything back to the way I like it. I guess you could say I am fortunate I encountered these issues so early on in the life of the phone rather than later on. Regardless, my battery problems do seem to be fixed, and for sake of completeness and the possibility of it helping others, I will also post my screenshots after a day or two of use after the reset.
Shinedowngirl87, to get that information to show, you have to enable developer options, and then in developer options, you just click on running services.
