1. jhimmel's Avatar
    Got a system update this morning on Verizon. Security update and a number of bug fixes.
    06-27-2017 04:31 AM
  2. 1812dave's Avatar
    the update fixed an annoying issue introduced with the 7.0 update: the screen would turn back on every few seconds during phone calls, after the power button was pressed to turn off the screen. the only workaround was to go from the call screen to the home screen; then press POWER. it has been fixed with today's Verizon update.
    06-27-2017 01:04 PM
  1. Share what's on your V20's 2nd screen!
    By flyingkytez in forum LG V20
    Last Post: 06-28-2017, 04:18 PM
  2. In my notification log it is showing android system ui
    Last Post: 06-27-2017, 04:14 PM
  3. Phone wont turn on unless battery is out?
    Last Post: 06-27-2017, 06:44 AM
  4. Hard reset fails on Benq/Kogan Kitkat 4.4.2
    Last Post: 06-27-2017, 04:12 AM
  5. Phone won't turn on without factory reset
    Last Post: 06-26-2017, 10:25 PM
