1. AC Question's Avatar
    Need a mock location app for S7 Edge.
    I've got a S6 edge and my friend got a S7 edge, now the mock app I use isn't working on my friends s7.
    So I want to know if there is a specific app you get for s7 edge?
    Or is the software on the s7 to new for a mock location.
    It does however give you the option for a mock location in the developer options but it's not working 100%.
    06-29-2017 01:02 AM
  2. NexusGirlX's Avatar
    I use FakeGPS. When you set it up, it tells you to set the GPS settings on the phone to device only. You can set your location in FakeGPS for anywhere in the world and Google maps will show that as your location. Posting on Facebook and Instagram will also show that location as your current location.
    I've used it on MM and Nougat.
    07-01-2017 03:53 AM
  3. bigslam123's Avatar
    I use Mockation and it works great
    07-12-2017 08:55 PM
  1. how do I get it to cut off for
    Last Post: 06-29-2017, 01:06 PM
  2. How do i restart a system app?
    Last Post: 06-29-2017, 01:04 PM
  3. Replies: 1
    Last Post: 06-29-2017, 01:02 PM
  4. Replies: 2
    Last Post: 06-29-2017, 07:17 AM
  5. AT&T Galaxy S8 Add full acess for non Google calendar apps.
    By Wally71 in forum Samsung Galaxy S8 & S8+
    Last Post: 06-28-2017, 04:08 PM
