1. Summertime_sadness's Avatar
    Suddenly i can't find the emoji button (left of space bar) i tried to rest the settings didn't work i can't also find it in the setting button when i hold it.
    07-02-2017 12:44 PM
  2. dm3ready's Avatar
    What keyboard are you using? Samsung? Google? Swiftkey? Regardless, it's probably an option that needs to be selected again in your settings.
    07-02-2017 02:34 PM
  3. Summertime_sadness's Avatar
    I use the Samsung keyboard
    07-03-2017 01:15 AM
  4. grunt0300's Avatar
    If you are using the Samsung keyboard, bottom row all the way to the right there is an arrow icon that points to the left. Hold that down for a second, and the emoji icon will appear on the left side of the bottom row.
    07-03-2017 09:51 AM
  1. Android central app. Can't login.
    By Karl Krasnowsky in forum Android Central Apps
    Last Post: 07-10-2017, 09:45 AM
  2. Replies: 1
    Last Post: 07-04-2017, 10:53 PM
  3. Why is my song download not stopping?
    Last Post: 07-03-2017, 01:52 PM
  4. Can I connect my Android 7 phone to powered USB-hub?
    Last Post: 07-02-2017, 03:51 PM
  5. Why does no call recording app work for my honor 6x
    By Matnetmat in forum Android Apps
    Last Post: 07-02-2017, 12:29 PM
