1. AC Question's Avatar
    S7 edge says fast charging when plugged in but its still old charging. Changed cables still the same. Sent it to Samsung who told me it was fine!
    Fast charging used to work but although says it is its the old way
    Any ideas
    07-09-2017 11:43 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it plugged into a wall outlet? Have you tried a different fast-charging plug (unless that's what you mean by changing cables)?
    07-10-2017 05:04 PM
  3. chanchan05's Avatar
    How do you mean to say it's not fast charging? How long does it take?
    07-10-2017 08:16 PM
  1. my mi note3 mobile charged 10% per hour
    Last Post: 07-10-2017, 05:18 PM
  2. Mod: Always On display Only while Charging.
    By ihearlivepplz in forum Samsung Galaxy S8 & S8+ Themes & Mods
    Last Post: 07-10-2017, 03:22 PM
  3. My s8 battery seems to drain to fast, can someone check?
    Last Post: 07-09-2017, 09:13 AM
  4. Replies: 1
    Last Post: 07-09-2017, 08:31 AM
