1. Mike Koenigsheim's Avatar
    Hi all - my homescreen has shrunk!
    All icons are smaller and I have a half inch gap at the bottom.
    Any clue how to fix this?
    Screenshot coming
    Attached Thumbnails Galaxy S7 edge homescreen shrunk-screenshot_20170712-213319.jpg
    07-13-2017 03:07 PM
  2. IAmSixNine's Avatar
    Did you make any font changes? or Zoom level changes?
    Go into Settings, Display and look for Screen zoom and font.
    07-14-2017 11:24 AM
  3. LDUK's Avatar
    Screenshot coming
    I have no idea why this happened but it happened on mine too.
    To fix it
    Settings>Display Settings>Screen Zoom and Font
    I changed the Zoom from small to medium, applied it, went back to my home screen, then back into the setting and changed the screen zoom back to small and it worked.
    05-02-2018 06:30 AM
  1. Why does my Galaxy Note Edge keep shutting down and going off on its own?
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 04-30-2018, 06:51 AM
  2. Galaxy Tab A 8-Inch SM-T350 Network issues
    By android_freak1 in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 08-04-2017, 04:07 PM
  3. Galaxy Note 4 and Samsung Flow
    By SouthFlaPi in forum Samsung Galaxy Note 4
    Last Post: 07-13-2017, 01:43 PM
  4. Why doesn't the Samsung Galaxy Note 3 not get the new emojis?
    Last Post: 07-13-2017, 09:45 AM
