1. Niks Latvietis's Avatar
    My s7 edge screen flashes when i unlock the phone,but after that it is completely black,i can swipe up and unlock it,i can use the touchscreen and side buttons for volume,i can see the top light if i have an sms or any notifications,i can hear every sound,vibrations. My screen is just black, does this mean the main motherboard is ok? And is it possible to get it working without fixing the display and glass screen?
    07-14-2017 10:08 AM
  2. anon(9602380)'s Avatar
    Welcome to Android Central.
    I suggest trying a hard reset. Hold your power and volume down button at the same time till you see it restart. Then let go of the buttons. Hopefully this will help with your issue. Thanks!
    07-14-2017 10:26 AM
  3. Niks Latvietis's Avatar
    I did that multiple times, when it restarts it goes into main screen and the screen flashes,then it is black,i can swipe up and unlock it ,hear everything ,i can use the lock to lock it again. If i unlock the phone again it flashes again and is black,but touch screen works.
    07-14-2017 10:32 AM
  1. Gear S2 screen wont turn on
    By AC Question in forum Samsung Gear S2
    Last Post: 07-20-2017, 12:30 PM
  2. Replies: 3
    Last Post: 07-17-2017, 11:36 AM
  3. Replies: 1
    Last Post: 07-14-2017, 05:36 PM
  4. put a lock screen now dont remember my pin for my sumsung
    Last Post: 07-14-2017, 11:57 AM
  5. Replies: 1
    Last Post: 07-14-2017, 04:16 AM
