1. AC Question's Avatar
    The service centre replaced the motherboard without informing me. My question is will my samsung S7 edge work the same way? will it get other related problems?
    07-16-2017 11:47 PM
  2. belodion's Avatar
    Sometimes, motherboards are indeed replaced in order to fix a problem. So if the diagnosis was correct, your problem should be fixed as permanently as anything can be fixed. Do you have reason to believe that the replacement was unnecessary or improperly done?
    07-17-2017 06:35 AM
  1. How is the updates from oneplus?
    By AC Question in forum OnePlus 5 & 5T
    Last Post: 07-28-2017, 05:02 AM
  2. why has my phone gone negative
    By John Burnett1 in forum Ask a Question
    Last Post: 07-19-2017, 02:54 AM
  3. Samsung S4 selfie is blurry at the bottom of the screen.
    By MagnoliaMS in forum Samsung Galaxy S4
    Last Post: 07-17-2017, 01:36 PM
