1. sashwat38's Avatar
    Hello.
    Sometimes while using my S7 Edge, a flicker appears...well it doesnt flicker but it shows like static it doesnt move and some secs later my phn restarts itself. Its running on Nougat 7.0. What shall I do? I dont think its display problem...it may be something from the inside. Maybe rooting causes these problems But im not sure whether its rooted or not. I used apps to check all shows its not rooted but I cant access secret folder or install my knox. Any help will be appreciated.
    07-20-2017 11:11 AM
  1. Why when go to my contracts and in account setting.
    By Kimbrat in forum Legacy Android & Other OS's
    Last Post: 07-20-2017, 03:23 PM
  2. Replies: 2
    Last Post: 07-20-2017, 01:38 PM
  3. Replies: 1
    Last Post: 07-20-2017, 10:05 AM
  4. Replies: 0
    Last Post: 07-20-2017, 07:35 AM
