1. Asger-P's Avatar
    Hi
    I have just bought a S7 edge and I like it very much, but I have a problem with the, for my eyes, very small images on the contacts, they are round and only 7mm in diameter, and they could easily be square an 12mm.
    When there is an incoming call the image of the person is also way smaller then it could be.
    Is there a way to make these images bigger ?
    Thanks in advance
    Best regards
    Asger
    07-31-2017 07:33 PM
  2. Asger-P's Avatar
    If ScreenZoom is increased, the images in contacts are also increased, which is a little better then nothing.
    ScreenZoom can be found in: settings -> Screen -> ScreenZoom and Font
    I'm not sure screenzoom is the right word, I translated it from Danish.
    Best regards
    Asger
    08-02-2017 12:19 PM
  1. Replies: 1
    Last Post: 01-18-2018, 09:18 PM
  2. Replies: 1
    Last Post: 08-01-2017, 12:34 AM
  3. Moved photos from DCIM folder and can't find them.
    Last Post: 07-31-2017, 07:41 PM
  4. Do the lg zone 3 has internet and talk at the same time?
    Last Post: 07-31-2017, 07:37 PM
  5. Replies: 0
    Last Post: 07-31-2017, 07:29 PM
