1. lizette1222's Avatar
    Hello, I set up my fingerprint on my device and a password as a back up, well now my dumb phone doesn't read my finger print and it tells me to restore it, but the only way to do it is by typing the password that I created, and for the life of me I cannot remember my password..so is there a way to go around that, or my only choice will be a factory reset? Thanks
    08-04-2017 04:18 PM
  2. Fit24's Avatar
    You can try to unlock your phone at findmymobile.samsung.com. If not then I think you'll have to do a hard reset.
    Did you do a backup?
    08-04-2017 04:45 PM
  3. lizette1222's Avatar
    a backup? I'm not sure, I don't think so..ill check the find my mobile site, thanks
    08-04-2017 04:49 PM
  4. ticketbabe2's Avatar
    Make sure it cannot read your fingerprint! Mine gets funky, but reads once I turn my thumb the right way & hold it
    08-05-2017 01:03 PM
  1. Show hidden notifications on lock screen with fingerprint
    Last Post: 01-01-2018, 03:48 PM
  2. Waiting time to restor my S7 app's from google account.
    By AC Question in forum Samsung Galaxy S7
    Last Post: 08-04-2017, 11:32 AM
  3. Waiting time to restor my S7 app's from google account.
    Last Post: 08-04-2017, 08:31 AM
  4. Replies: 1
    Last Post: 08-02-2017, 11:47 AM
  5. Can't restore Samsung keyboard from telephone keypad layout
    Last Post: 08-02-2017, 08:21 AM
