1. Hellfire's Avatar
    Watch out everyone the S7 Edge also has battery issues, not just the note 7!
    Over the last few months I’ve noticed a decline in battery life on my S7 Edge, and from time to time it would be a bit warm, but I’ve always kept it in an Otterbox so didn’t think much of it. However, I took it out of the case to switch sim cards and noticed my back of my phone had separated from the front around the corner.
    Turns out the battery had exploded, and as I’ve had the phone for one year and four months it is out of warranty and Samsung told me to go get it fixed myself, they couldn’t care less.
    Attached are some pictures of the battery, as I asked a shop to replace it for me.
    Anyone with a S7 Edge watch out - their batteries suck as well and my blow up on you and Samsung doesn’t care.
    Expanding Battery S7 Edge !!-20170808_204540.jpgExpanding Battery S7 Edge !!-20170808_204557.jpgExpanding Battery S7 Edge !!-20170808_204621.jpg
    08-08-2017 10:20 PM
  2. L0n3N1nja's Avatar
    It's not just a Samsung issue, it can happen to any device. iPhones have caught fire for years, and I've personally seen a couple Motorola phones where the screen was being pushed off the front by a bulged battery, one of them was a Droid Maxx.
    Thanks for sharing the images.
    WalkingHorse likes this.
    08-08-2017 10:31 PM
  3. chanchan05's Avatar
    This isn't a specific S7 Edge issue.😊
    08-08-2017 10:33 PM
  4. Tsepz_GP's Avatar
ID:	265450Click image for larger version.
ID:	265451Click image for larger version.
    Your battery EXPANDED, it did not explode.
    Lithium Batteries do this overtime.
    Mods please change the title to expanded.
    08-09-2017 04:16 AM
  5. Tsepz_GP's Avatar
    It expanded, it did not explode. His phone did not catch fire.
    Battery Expansion is a major Side Effect with Lithium Batteries, some do it, some don't, really depends on the battery.
    My Nokia N80's battery expanded back in 2006, had to replace it.
    08-09-2017 04:19 AM
  6. NexusGirlX's Avatar
    I've even had batteries expand in two Apple laptops. It happens all the time with anything battery operated.
    Tsepz_GP likes this.
    08-09-2017 11:16 AM
  7. Iva_LadyDiCaprio98's Avatar
    That is definitely not an explosion. Like the others have said, lithium-ion batteries have been known to expand over time.
    08-12-2017 12:47 PM
  8. sydneycooper1979's Avatar
    Mod Note: clarified title.
    08-12-2017 12:55 PM
  9. Hellfire's Avatar
    Well there were burn marks on the inside of the phone where the battery sits, hence exploding.
    08-12-2017 12:59 PM
  10. sparksd's Avatar
    Expanding lithium batteries are an on-going issue with Dell XPS laptops, too. As others have said, this is a broad problem.
    08-12-2017 04:16 PM
  11. NexusGirlX's Avatar
    I don't know if you can still call that exploding.
    I had a MacBook battery expand inside the computer. I took the plastic case apart and I could see the individual cells were puffy and filled with gas. just for fun, I took a pin and punctured one of the puffy cells and immediately a flame came out of it. It wasn't an explosion, just the gaseous chemicals mixed with air caught fire just for a second as they leaked out. That sounds like what may have happened to your phone. The individual cell expanded so much that it couldn't hold anymore of that battery gas and it leaked out and burned up.
    08-13-2017 02:56 AM
  12. rschon092755's Avatar
    Yes. Mine is still in the case but Samsung doesn't seem to think they have a problem.
    Let me know if you can think of a solution
    08-21-2017 01:34 PM
  1. Battery life question
    By bryanmsi in forum Moto Z2 Play
    Last Post: 09-11-2017, 04:35 PM
  2. DONT do this with your S7, Crazy!!!
    By phatphoneguru in forum Samsung Galaxy S7 edge
    Last Post: 08-14-2017, 06:53 PM
  3. Pixel Launcher Draining Battery
    By AC Question in forum Google Pixel & Pixel XL
    Last Post: 08-14-2017, 03:29 PM
  4. Pixel Launcher Draining Battery
    Last Post: 08-12-2017, 12:04 PM
  5. Replies: 0
    Last Post: 08-12-2017, 10:20 AM
