A
I don't remember the Note 4 having Quick Charge though.There is no difference in the chargers from what I can tell. When I got my S8+, first thing I did was look at the outputs on the Note 4, S7 Edge and S8+ chargers and they looked the same other then the S8+ charger being black. I have a black S8+. I'm not sure if the colors on the chargers are different depending on phone color.
I am using a combo of chargers between the Note 4, S7 Edge and S8+ and they all work great, no difference in charging speeds.
I have both the Note 4 and the Note Edge. Both have quick charge.
I've been using the same cable with no problems. That doesn't look like the same cable that came with my Note 4. I am in the US if that makes a difference. The black insert is a solid piece, not broken in two sections like yours is.There is a major difference. The connector has two parts even though it's one piece. I have both phones, btw. This is a pic of the Note 4 charger cable connector. Most of you already know what the S7 looks like. Oh, I should clarify. You can use the same charger, but NOT the same cable.
I think that cable came with the note3 and some Samsung tabletsThere is a major difference. The connector has two parts even though it's one piece. I have both phones, btw. This is a pic of the Note 4 charger cable connector. Most of you already know what the S7 looks like. Oh, I should clarify. You can use the same charger, but NOT the same cable.
That's a Note 3 charger.There is a major difference. The connector has two parts even though it's one piece. I have both phones, btw. This is a pic of the Note 4 charger cable connector. Most of you already know what the S7 looks like. Oh, I should clarify. You can use the same charger, but NOT the same cable.
Yes, I do it daily.I'm looking to upgrade from the Note 4 to the S7 edge and want to use the same charger.
It can work for you, but you'd better use the original charger
