1. AC Question's Avatar
    I'm looking to upgrade from the Note 4 to the S7 edge and want to use the same charger.
    08-10-2017 01:00 PM
  2. Dooki's Avatar
    it will work. might not charge as fast though
    08-10-2017 03:47 PM
  3. anon(5719825)'s Avatar
    There is no difference in the chargers from what I can tell. When I got my S8+, first thing I did was look at the outputs on the Note 4, S7 Edge and S8+ chargers and they looked the same other then the S8+ charger being black. I have a black S8+. I'm not sure if the colors on the chargers are different depending on phone color.
    I am using a combo of chargers between the Note 4, S7 Edge and S8+ and they all work great, no difference in charging speeds.
    08-11-2017 01:27 AM
  4. chanchan05's Avatar
    I don't remember the Note 4 having Quick Charge though.
    08-11-2017 01:36 AM
  5. anon(5719825)'s Avatar
    I have both the Note 4 and the Note Edge. Both have quick charge.
    08-11-2017 01:47 AM
  6. WowSpring6's Avatar
    if the current and the voltage is the same on the adapter, it can be interchangeable.
    08-11-2017 04:57 AM
  7. sparksd's Avatar
    Same here and concur (S7 Edge, not Note Edge).
    08-12-2017 04:19 PM
  8. L0n3N1nja's Avatar
    Note 4 was Samsung's first phone with adaptive quick charge.(First available on Verizon at least)
    Note 4, Note 5, S6, S7 all used the same micro USB port and wall plug.
    08-12-2017 05:32 PM
  9. Bankokbob54's Avatar
    There is a major difference. The connector has two parts even though it's one piece. I have both phones, btw. This is a pic of the Note 4 charger cable connector. Most of you already know what the S7 looks like. Oh, I should clarify. You can use the same charger, but NOT the same cable.
    Can I use the same charger for a Galaxy Note 4 and the S7 Edge?-20170813_164352.jpg
    08-13-2017 03:46 AM
  10. anon(5719825)'s Avatar
    I've been using the same cable with no problems. That doesn't look like the same cable that came with my Note 4. I am in the US if that makes a difference. The black insert is a solid piece, not broken in two sections like yours is.
    08-13-2017 09:55 AM
  11. VannM's Avatar
    I think that cable came with the note3 and some Samsung tablets
    08-13-2017 09:57 AM
  12. anon(5719825)'s Avatar
    Also, the cable that came with the Note 4/Note Edge is longer on length then the cable that comes with the S7. They shortened it a bit and the cable itself is a bit more rubber like and thinner.
    08-13-2017 10:02 AM
  13. chanchan05's Avatar
    That's a Note 3 charger.
    08-13-2017 05:00 PM
  14. Bankokbob54's Avatar
    And you are correct! Apologies. It's my spare phone and I don't use it that much.
    08-13-2017 11:15 PM
  15. Tsepz_GP's Avatar
    Yes, I do it daily.
    08-16-2017 05:10 PM
  16. MomoMilky's Avatar
    We have a mix of s7edges and note4s in my house. We all use the same chargers and cables, no problems.
    08-17-2017 10:56 AM
  17. amazingkyo's Avatar
    They could use the same cords and adpaters .
    08-21-2017 05:00 AM
  18. SexyLi's Avatar
    It can work for you, but you'd better use the original charger
    08-21-2017 05:15 AM
  19. anon(5719825)'s Avatar
    The chargers are the same.
    08-21-2017 09:38 AM
  1. Sony Xperia XY Premium VS Samsung Galaxy S8 full review
    By krazyatom in forum Sony Xperia XZ
    Last Post: 10-23-2017, 03:35 AM
  2. Replies: 1
    Last Post: 09-16-2017, 06:50 PM
  3. Galaxy s4 front camera button never works
    Last Post: 08-10-2017, 12:51 PM
  4. Can you use the same charger for a note 4 & S7 edge
    Last Post: 08-10-2017, 12:41 PM
  5. How to use calendar on U8 Smartwatch
    Last Post: 08-10-2017, 10:43 AM
