1. Air Planet's Avatar
    Why 5ghz dualband wifi not showing in our some devices like Galaxy S7 edge even these devices have 5ghz recieving capability in specs and am trying this using linksys wifi router ac dualband?
    08-10-2017 01:04 PM
  2. B. Diddy's Avatar
    Does your 5 GHz SSID have a different name from the 2.4 GHz SSID? Make sure they're different.
    08-11-2017 02:48 AM
  3. Air Planet's Avatar
    Yes both have different names.
    08-11-2017 02:58 AM
  4. fsfty's Avatar
    I had nothing but problems using WiFi calling and Video calling using the 5ghz Wifi. Went back to 2.4 everything works fine again.
    08-11-2017 08:42 AM
  5. Air Planet's Avatar
    But 5ghz not showing in my s7 edge.
    08-11-2017 09:37 AM
  6. B. Diddy's Avatar
    Are you near the router? 5 GHz gives higher maximum throughput, but lower range compared with 2.4 GHz. If you're relatively far from the router, the signal might not be strong enough.
    08-11-2017 10:01 AM
  7. Air Planet's Avatar
    Yes am near the router
    08-11-2017 12:51 PM
  8. B. Diddy's Avatar
    Rebooted the router (by unplugging its power for 10 seconds)?
    08-11-2017 07:14 PM
  9. Air Planet's Avatar
    Still not working
    08-17-2017 03:26 PM
  10. B. Diddy's Avatar
    You mentioned that 5 GHz isn't working on "some devices" -- does this mean that you've tested it out on another device besides this S7 edge?
    08-19-2017 02:58 AM
  11. Air Planet's Avatar
    I means other samsung devices too but apple devices found 5ghz wifi.
    08-19-2017 03:15 AM
  12. B. Diddy's Avatar
    Are these Samsung devices able to connect to 5 GHz on other routers without difficulty?
    08-19-2017 03:23 AM
  13. Air Planet's Avatar
    No same issue occured with other routers too
    08-19-2017 03:29 AM
  14. B. Diddy's Avatar
    Hmm, strange. I wonder if it's a firmware issue that's specific to Samsung. Have you already Safe Mode, or wiping the cache partition?
    08-19-2017 03:44 AM
  15. Air Planet's Avatar
    08-19-2017 04:24 AM
  16. B. Diddy's Avatar
    08-19-2017 12:55 PM
  17. Shinigami Mai's Avatar
    Are you using the low band for 5ghz chanels 36 to 48 set on router.
    08-19-2017 06:48 PM
  1. Can I use the same charger for a Galaxy Note 4 and the S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 08-21-2017, 09:38 AM
  2. Facebook Whatsapp (Android only) issues on Wifi not Cellular
    Last Post: 08-14-2017, 12:20 PM
  3. Can you use the same charger for a note 4 & S7 edge
    Last Post: 08-10-2017, 12:41 PM
  4. Why will my S6 no longer connect to wifi?
    Last Post: 08-10-2017, 12:25 PM
  5. T-Mobile WiFI Calling Issue
    By supaeuro in forum HTC U11
    Last Post: 08-10-2017, 11:23 AM
