1. OTAKUDYANNE 1234's Avatar
    I recently noticed that half of my screen is covered with this yellowish tint and I couldn't find any related article for it. I'm sure that its not the blue filter since I turned it off. Do you have an idea if its a problem with the recent software update? Or is it a hardware problem? Any help would be appreciated. Thanks!
    08-14-2017 02:30 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Nougat forum to the S7 edge forum.
    Does this persist after a reboot? Or in Safe Mode? https://support.t-mobile.com/docs/DOC-24999
    08-14-2017 05:29 PM
  3. Sams6's Avatar
    This sounds like you may have screen burn-in. If it's half of the screen, it was most likely caused by the keyboard.
    B. Diddy likes this.
    08-14-2017 06:00 PM
  4. honda-Dave's Avatar
    That's exactly what it is, I have 2 big lines going accross my screen, and you can only really see it when the screen is white.
    08-15-2017 06:18 AM
  1. Wipe Screen Partition
    By Bankokbob54 in forum Samsung Galaxy S7
    Last Post: 08-15-2017, 07:20 AM
  2. Remove ringtone name on lockscreen
    Last Post: 08-14-2017, 05:39 PM
  3. How do I transfer photos from my phone to the SD card?
    Last Post: 08-14-2017, 12:54 PM
  4. Why doesn't my phone set up the mail account itsverizon.net
    Last Post: 08-14-2017, 12:13 AM
  5. Why do I need to enter a pin to power off my kid's tablet?
    Last Post: 08-13-2017, 11:53 PM
