Galaxy Note 10 Deal: BOGO at Verizon!
  1. cheesy666's Avatar
    There is a small gold colored piece, part of my headphone jack that is sticking out. This piece is preventing me from being able to plug in my headphones. What is it and how do I fix it?
    Apologies for blurry photo, it was taken off of an iPhone 4 *shudders*. But I believe that the gold piece is still visible.
    Attached Thumbnails How do I fix my broken headphone jack?-img-20170814-wa0004.jpg
    08-14-2017 10:01 AM
  2. N4Newbie's Avatar
    I would suggest you get the job done by a pro. But, if you feel you are up to it, then...
    08-14-2017 10:20 AM
  3. motorcycle_monkey's Avatar
    I had mine for 8 months and had a pin go bad. Since it was still under warranty, just got a replacement. PIA to have to set up a new phone, but, worth it to have a working right ear on my headphones.
    08-14-2017 03:57 PM
  1. Replies: 8
    Last Post: 09-08-2017, 10:41 PM
  2. Replies: 4
    Last Post: 08-16-2017, 07:14 AM
  3. Sony xperia L sometimes vibrates how to close my mobile I can't close it
    By Farida Zainulabdin in forum General Help and How To
    Last Post: 08-14-2017, 10:35 AM
  4. the toothpick method reboot isn,t working on my android box
    Last Post: 08-14-2017, 09:04 AM
  5. my remote control will not let me reboot my kodi mxq tv box
    Last Post: 08-14-2017, 08:44 AM
