1. cwy's Avatar
    The Samsung forum has this long thread about S8 users having slow Wi-Fi LAN file transfer speed. I have the same problem on my S7 Edge with Nougat. One curious thing is that when I upload from smartphone to PC, I get normal speed, which, for me, is about 366 kilobytes/second under 802.11g. I know this is normal because I get the same speed (up and down) on my Note 3 with Lollipop. But on my S7 Edge, the speed I get while downloading from PC to smartphone is just 117 KB/s. Downloading from PC, of course, is the more common thing to do than uploading, so this is not ideal. Is anyone's experience regarding this issue same as mine? I use this File Manager app to all the LAN file transfers. And my PC is Windows 7.
    08-15-2017 12:47 PM
  2. sparksd's Avatar
    On my S7 Edge running Nougat, I just transferred a 109MB file from a PC (Win 10) to internal memory on an 802.11 b/g/n network (2.4GHz) and got about 400KB/s. I used ES File Explorer Pro.
    Have you tried other networks to see if the transfer speed is consistent? Are Internet speeds as expected?
    08-16-2017 10:35 AM
  3. cwy's Avatar
    What is your speed when you transfer from smartphone to PC?
    I get great (as expected) speed for both wired and wireless Internet connection. The only slowness is for downloading (not upload) with wireless LAN connection.
    I tried it at my home network and office network and got the same results.
    08-16-2017 12:29 PM
  4. Shinigami Mai's Avatar
    The problem is the smb protocol in android it to complex to explain use ftp you will get full speed add a free ftp server to win 10 and set up es to access that.
    08-16-2017 12:41 PM
  5. cwy's Avatar
    I just tried ES File Explorer and suddenly I could download and upload at 1 megabyte/second with 802.11b/g 2.4GHz. So I guess the slowness is due to the Android file transfer app. It is my turn to ask you why you get only 400 kilobytes/sec.
    08-16-2017 12:52 PM
  6. cwy's Avatar
    When I use ES File Explorer I get what I think is my normal speed for 802.11b/g 2.4GHz: 1 megabyte/second transfer speed. And I use "LAN" instead of FTP in ES. Hence, it seems my slowness (366 and 117KB/s) was due to the Android file transfer app I used before.
    08-16-2017 01:01 PM
  1. In-Store demos?
    By LonestarROB in forum Samsung Galaxy S8 Active
    Last Post: 08-16-2017, 12:26 PM
  2. how to know about my transfer hostory if it was deleted
    Last Post: 08-16-2017, 01:41 AM
  3. ZTE and WI-FI
    Last Post: 08-15-2017, 12:16 PM
  4. Facebook not remembering Android sign in from app or browser.
    By everway9 in forum Samsung Galaxy S8 & S8+
    Last Post: 08-15-2017, 12:04 PM
  5. Icons in galaxy s8+
    By kalpit18 in forum Samsung Galaxy S8 & S8+
    Last Post: 08-15-2017, 11:31 AM
