1. Pinmac's Avatar
    Some while ago I found on the net somewhere some suggested settings for Pro mode in certain circumstances. I put a shortcut on my home screen to be able to access this directly and it worked well. Suddenly I cannot even get Pro mode to focus at all. The Tracking AF button is greyed out in Settings is greyed out so I don't know if this is the problem?
    08-15-2017 06:25 PM
  2. SpookDroid's Avatar
    Yup, that's probably why. If the AF button is greyed out, focus is set to a fixed point, so unless you're pointing to anything in that distance, your pictures will be blurry. Check your Focus settings on Pro Mode.
    08-15-2017 09:00 PM
  3. Pinmac's Avatar
    Thank you! Somehow my focus setting had got stuck on Macro. I've reset it and the Tracking AF is now available. Thanks again.
    SpookDroid likes this.
    08-16-2017 08:39 AM
  4. SpookDroid's Avatar
    No problem! Glad you got it fixed Pro Mode can be a blessing or a curse, depending on how well you can adjust each setting. For the most part Auto Mode should work, but when using Pro Mode, you have to look at every setting or you might be using something that worked for a past 'scene' and it won't do for your next shot.
    08-16-2017 11:07 AM
  1. Galaxy S8 spying on me through photos?
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 08-17-2017, 05:55 PM
  2. Replies: 1
    Last Post: 08-16-2017, 01:09 AM
  3. My samsung tablet e appears nit to have a menu in my files
    Last Post: 08-16-2017, 01:05 AM
  4. Replies: 3
    Last Post: 08-15-2017, 10:38 PM
  5. Replies: 1
    Last Post: 08-15-2017, 08:39 PM
