1. jmagid51's Avatar
    I have no WiFi or internet, how can I cast the screen on my S7 Edge to my TV?
    08-16-2017 08:47 PM
  2. SpookDroid's Avatar
    Most TVs support direct connections (WiFi Direct), so just set your TV to its screen sharing input and then set the S7 to
    Screen Mirroring (or Smart View, can't remember what it's called there) so that it can see the TV.
    If your TV, however, doesn't support direct connections, then you won't be able to wirelessly cast your screen without a router in the middle.
    08-16-2017 09:51 PM
  3. Robert Lindsay's Avatar
    there is serious lag using the screen mirroring or smartview features, if you use the you tube app on your phone and cast to the youtube app on your tv, this seems to be ok for me as far as lip sync goes.
    08-17-2017 07:57 PM
  4. SpookDroid's Avatar
    'Lag' should only occur if your network doesn't have enough bandwidth or if your connection is not strong enough. Since the OP mentioned that they don't have an Internet connection on the TV, your 'app' suggestion will not work in this case.
    08-17-2017 09:05 PM
  5. Robert Lindsay's Avatar
    i wish the smartview would work but audio sync is miles out, im not suggesting bt broadband is ace but it should not be a problem, if i use the your tube app everything is fine, if i try to use screen mirroring or the smartview app, lip sync is out by miles, if anyone can suggest a fix then fine then im all ears, so far Samsung support are a bit **** to say the least.
    does smartview work for you without lip sync issues?
    08-17-2017 09:16 PM
  6. SpookDroid's Avatar
    Yup, no issues on mine. When you use the YouTube app on your TV (or a Chromecast), it's the app doing the actual download, not your phone. With screen mirroring, it's the phone doing all the work, and then beaming the image and audio to your TV...that does take some processing, so I forgot that part: if your TV or phone (or both) processors are either not fast enough or are doing other things, image might suffer, and sometimes, audio sync. It also is app-dependent sometimes, unfortunately.
    But for the most part, it's worked OK for me. No audio sync problems to a 3-year-old Samsung TV.
    Robert Lindsay likes this.
    08-17-2017 11:54 PM
  7. Robert Lindsay's Avatar
    Im glad to hear it does work for some people. As you say it will take alot of processing for this but you would think they would not have made the feature available if it did not work well. My Samsung s7 phone should be powerful enough, it has a lot of stuff disabled too so it not running other things. Maybe the tv i not up to the job, when i start my tv i have to wait about 30 second before i can use the remote and change the source input, its as if its waiting on the system fully loading like a pc.
    08-19-2017 06:25 PM
  8. L0n3N1nja's Avatar
    Gotta correct you, there are ways to cast without a router. Microsoft's Miracast doesn't require home internet or a router. I have one plugged into the HDMI of my TV and screen mirror my phone for Netflix and other streaming.
    mperkinsnz likes this.
    08-19-2017 08:36 PM
  9. SpookDroid's Avatar
    That's WiFi Direct right there
    08-19-2017 09:14 PM
  10. Serkle K's Avatar
    So I have a question... What settings do I need to check so I can watch what's on my TV, on my phone?
    I have 2 Samsung Smart TVs, and when I had the Note 7, I was able to mirror from my TV to my phone easily.
    Now, I swear I've also done this on my S7E after I got it, to watch Football while doing stuff in the kitchen, and for some reason, recently, I can only mirror one way from my phone to my TV, but not the other way.
    I've tried to search settings for Mirroring but I didn't find anything that helped.
    Any thoughts?
    08-21-2017 10:39 AM
  11. SpookDroid's Avatar
    On the newer phones that has been moved to the 'Smart View' menu. If you're on the same WiFi and the TVs are supported, you should see the option to cast from TV on the Smart View pop-up. Also check your router if there have been any configuration changes that might be blocking the mirroring traffic packets or VPN that might be active as this might restrict your phone's ability to see the TVs in the network.
    If that doesn't work you can try and find an old version of the SmartView app (version 2, I believe) as the latest version on the Play Store removed the ability to mirror from TV as they planned to include that with the phone.
    08-21-2017 11:08 AM
  12. Serkle K's Avatar
    Thanks! I'll check my TV setting when I get home.
    08-21-2017 12:01 PM
  13. SpookDroid's Avatar
    Hope it works! In my case, I have to use the SmartView old app for one of my TVs (2014 model), but my newer TV (2016) does work directly from the phone's SmartView menu. I can also control the latter with my phone via WiFi, whereas the first I need an IR Blaster.
    Serkle K likes this.
    08-21-2017 12:22 PM
  14. Serkle K's Avatar
    I think I figured it out. for some strange reason, I had to download smart connect, even though I can see my TVs from my phone. it now let's me view my TV on my phone. While I was able to see the TVs available, for some reason, view TV on device was missing. it had to have been an update that changed it. I had it before, but in any case it's working now. thanks guys!
    SpookDroid likes this.
    08-21-2017 07:15 PM
  15. SpookDroid's Avatar
    Glad you got it working! It's quite an useful feature if you have the TV service to take advantage of it.
    08-21-2017 11:54 PM
  16. jmagid51's Avatar
    Problem solved. Used smart screen with an Anycast M2 Plus. copies everything to the tv with no delay. total cost $15.00. Works like a champ.
    08-31-2017 08:57 PM
  17. hasasimo's Avatar
    3 weeks of searches, still can't find a way to cast my father's S7 Edge to his TV. I tried wired solutions and Microsoft's Display Adapter (since it was suggested on this forum). It simply does not work without wifi, tried it on a few different phones now.
    12-26-2017 03:24 PM
  1. Galaxy tab a(2016) unresponsive screen
    Last Post: 08-16-2017, 10:15 PM
  2. How to fix a broken screen on a tablet?
    Last Post: 08-16-2017, 10:13 PM
  3. Sound appear on the screen
    By Jeya Lakshmi in forum Ask a Question
    Last Post: 08-16-2017, 10:03 PM
  4. Nasty message about "Screen Overlay Detected"
    Last Post: 08-16-2017, 07:20 PM
  5. Screen repair
    By Brandon Mangrum in forum General Help and How To
    Last Post: 08-16-2017, 05:29 PM
