1. AC Question's Avatar
    It makes unwanted changes to words; it capitalizes the first letter of words randomly incorrectly, for example in the middle of a sentence; it changes words after they are typed; it makes incorrect "corrections" on its own. Where are the settings to control its operations found ?
    08-19-2017 09:32 AM
  2. SpookDroid's Avatar
    It depends on which service you're using for voice dictation, but settings for all available ones should be in the Language and Input section of your phone's settings. IF the voice dictation service is particular to the keyboard you're using, then it needs to be adjusted in the keyboard app's settings.
    08-19-2017 04:03 PM
  1. Samsung galaxy grand 2 network problem
    By Mukesh kumar30 in forum Samsung Galaxy Grand
    Last Post: 08-27-2017, 05:00 PM
  2. Google voice not working
    Last Post: 08-19-2017, 02:53 PM
  3. Replies: 1
    Last Post: 08-19-2017, 09:28 AM
  4. What does the Red "X" on my battery mean?
    Last Post: 08-19-2017, 08:47 AM
  5. boot repair galaxy s4 mini
    Last Post: 08-19-2017, 08:38 AM
