1. AKFL3TCH3R's Avatar
    I find myself charging this phone multiple times a day. I have a lot of features I don't use turned off. And then connectivity issues as well. Android OS drainage.
    08-22-2017 03:27 PM
  2. Dngrsone's Avatar
    Well, connectivity issues will certainly lead to poor battery life...
    08-22-2017 04:58 PM
  3. Tsepz_GP's Avatar
    Are you in an area with poor signal? If not and you are still having connectivity issues you may have a faulty unit.
    Do you have a case on it?
    08-23-2017 01:53 PM
  4. AKFL3TCH3R's Avatar
    I think it may just be my place of work. Only few areas actually have a problem with showing signal but pulling no data.
    08-24-2017 12:03 AM
  5. AKFL3TCH3R's Avatar
    I have a spigen dual layer case on it.. maybe the phone heats up in it and drains battery that way?
    08-24-2017 12:08 AM
  6. Dngrsone's Avatar
    In my experience, any time you are in an area of low to no connection to the cell towers, your battery will drain significantly because the phone is transmitting at highest power to try and maintain contact with said tower.
    If you are able to connect to Wi-Fi at work instead, that may improve your battery life. If you are able to live without phone access during work, then try setting airplane mode while at work.
    08-24-2017 03:49 AM
  7. SexyLi's Avatar
    Have you ever opened lots of software that you don't use?? You can close those software for your phone.
    08-24-2017 04:13 AM
  8. JOC2016's Avatar
    The single most effective saver of battery on my S7 edge is to turn down the brightness of the display to around 30% on the slider - after 10 mins you won't notice you've done so. I also find turning off the GPS when I don't need it is helpful.
    08-30-2017 06:39 AM
  9. bedscenez's Avatar
    After full charge my Estimated Battery Life was 10hrs 30 mins. Is that normal. Also notice some faster battery drain after Nougat Update. Last time i used skype and youtube for 1 hour battery was around 75%
    08-30-2017 07:45 AM
  10. Qc_Anubis's Avatar
    I have a spigen dualed layer aswell and no has nothing to do with it.
    Question for ya: have you done a factory reset or cleared cache memory when you upgraded to 7.0 ?
    Most people recommend you do one of these when you do major updates (like moving from 6.0 to 7.0 not 7.0 to 7.1)
    08-30-2017 09:07 AM
  11. Fit24's Avatar
    If I'm in an area with low or reduced signal coverage, I usually apply Maximum Power Saving Mode.
    09-02-2017 09:48 AM
  12. Abbers727's Avatar
    The only issue with that, is you won't know if you have low signal coverage unless you looked at your phone and can see that it has low signal coverage.
    At work, I put my phone on airplane mode.
    09-06-2017 08:23 PM
  1. my s6 full of prob ...§§§§!!!!!! help
    By AC Question in forum Samsung Galaxy S6
    Last Post: 08-24-2017, 07:36 AM
  2. My Toshiba keeps restarting every 10 or 15 seconds
    Last Post: 08-22-2017, 04:09 PM
  3. How do I resize pictures in my photo gallery for email
    Last Post: 08-22-2017, 03:51 PM
  4. Replies: 0
    Last Post: 08-22-2017, 03:20 PM
  5. my s6 full of prob ...§§§§!!!!!! help
    Last Post: 08-22-2017, 02:23 PM
