H8FKAndroid
Active member
No. Charge now. You should not ever let a lithium ion battery go down below 40%. At least not when you can help it. It creates more wear and tear for the battery internals. Regularly depleting it ti below 5% actually runs the risk of killing it.
That's true and all, but when I'm testing, I do let it go as low as I need.
It's the "regularly" part that does the damage.
Just once wouldn't do anything bad...
EDIT: For a while I used a piece of software to warn me when battery dropped to 30% or reached 80% during charging - I was only using it between those two extremes, charging up to 3x per day!
You should see how wonky the percentages go, when you do that! They have no problem adding up to numbers well above 100... At one point my Android System usage was at 74%! That must have been when I figured out, how the new and "improved" percentages work...
(It only resets the counter once you charge above 90%)
