1. AKFL3TCH3R's Avatar
    Does the edge panel cause any noticeable battery drain? I actually use it quite a bit, but I fear that having more panels would cause more trouble perhaps?
    09-17-2017 12:00 PM
  2. PJRed2008's Avatar
    If you use live panels that update feeds they'll use battery. If you use panels that are essentially pickers then you'll never notice the difference.
    09-17-2017 12:02 PM
  3. chanchan05's Avatar
    Consider the Edge panel as another set of widgets. So depends on what you put in there. The news panel should use as much as a news widget, etc.
    09-18-2017 08:31 PM
  1. Replies: 1
    Last Post: 09-29-2017, 12:12 PM
  2. Rss edge panel " No longer supported"
    By Davie Young in forum Ask a Question
    Last Post: 09-20-2017, 02:58 PM
  3. Samsung Tablet in chinese and no google apps after factory reset
    By Poodgeheid in forum General Help and How To
    Last Post: 09-18-2017, 04:36 PM
  4. Lock screen question
    By tonydroid99 in forum Samsung Galaxy Note 8
    Last Post: 09-17-2017, 12:10 PM
  5. Can I fix the speech to text feature, so it works better?
    By Michael Kingsbury in forum Samsung Galaxy Tab S3
    Last Post: 09-17-2017, 11:51 AM
