1. Abbers727's Avatar
    Does anyone think having dark themes on your phone, really helps save battery? I know it might not help a lot. I don't know. I was wondering what other people's opinions were.
    09-17-2017 10:39 PM
  2. chanchan05's Avatar
    It 'should', simply because less of the screen uses battery. But it still depends on other things more.
    09-18-2017 02:35 AM
  3. Abbers727's Avatar
    Okay. For a few hours, I used the default theme and I was like, "Noo. I can't get use to this. It's too much white." I just downloaded 'High_contrast_theme_II' I think maybe, I just use my phone a lot. (Not for phone calls. Or even text very often. But I use apps a lot.) I always feel like it looses battery kind of quick. But that might be because I use the AOD. I still charge it about one time a day depending where the % of battery left is when I have to go somewhere.
    09-18-2017 08:26 PM
  4. chanchan05's Avatar
    I charge around 2-3x a day because I only charge up to 90% then plug it back in once it goes below 50%.
    So yeah, I'll probably charge once a day if I let it go low. And I'm a pretty heavy user.
    09-18-2017 08:28 PM
  5. Abbers727's Avatar
    Yeah, I'm kind of heavy user. Most times, I charge to 100%. Sometimes, I let it go as low at 15% or sometimes, 30 or 40%. Then fully charge it to 100%. But if I did it the way you did it, I'd probably be charging my phone that often too. Or even charging it up to 95 or almost 100%. I'd probably be possibly charging it 2 times a day. I don't know if I should be letting it fully charge but sometimes, I'm charging it over night especially if I have work all day the next day.
    09-18-2017 08:41 PM
  1. Themes, Navigation bar.
    By ROE_HUNTER in forum Samsung Galaxy Note 8
    Last Post: 09-19-2017, 04:49 AM
  2. Replies: 2
    Last Post: 09-18-2017, 03:39 PM
  3. Is there any themes that change the built in email app background color
    By magichoward in forum Samsung Galaxy Note 8
    Last Post: 09-17-2017, 11:09 PM
  4. T-Mobile Galaxy S8 Samsung Theme Store
    By grunt0300 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-17-2017, 06:44 AM
  5. GBoard dark theme misspelled word display bug....
    By AdamHLG in forum Samsung Galaxy Note 8
    Last Post: 09-15-2017, 10:32 PM
