Heart rate monitor won't finish.
Tori_kara
Every time I try to use the S Health monitor for any option, it shows a heartbeat but says measuring no matter how long I wait. How do I get it to give me a result?
chanchan05
Q&A Team
Nov 22, 2014
8,519
Well it should stop measuring
There's supposed to be a percentagr indicator as to when it will stop measuring, as in the screenshot below.
Lauren Goetz
cablebrain
Same here, but this only started happening recently. It used to work fine for me. It keeps going and going, like the Energizer Bunny.
pawprints86
193
i know this is older, but I was having the same issue with the nonstop heart line. it was reading, the sensor worked, but it never showed a percentage. Not sure if any of you are root users, but it turns out i had frozen a package called "com.samsung.android,sm" which is apparently needed to actually record the measurement. I get the percentage now like youre supposed to, all i did was unfreeze that one package. Just wanted to give a heads up in case anyone else has the same issue going on :)
RemusGhostofRome
