1. Abbers727's Avatar
    I had a software update not too long ago. I think ever since then, I've had WiFi issues. Like things won't load right when I have WiFi on and I don't think it's the network connection.
    09-20-2017 09:11 PM
  2. lordofalllords's Avatar
    Does all the other devices work well? Do the other devices have working and perfectly fine network?
    09-20-2017 09:41 PM
  3. Abbers727's Avatar
    I think so. my iPad has been struggling with network connection a little. But that was even when I was out of state. Where I was trying to connect to a hotel's free wifi and couldn't do it. Occasionally, I have to re-log myself back into Facebook and Messenger on my iPad. I don't have that issue on my phone though. I don't use wifi too much on my kindle.
    It mostly works fine on my iPad besides having to re-log in to Facebook app and Messenger on the iPad.
    And the WiFi is fine on my computer.
    09-20-2017 09:47 PM
  4. Abbers727's Avatar
    I reset my networks so I hope that helped.
    09-20-2017 10:54 PM
  5. B. Diddy's Avatar
    Did you also try wiping the cache partition? https://support.t-mobile.com/docs/DOC-24999
    09-21-2017 11:54 AM
  6. Abbers727's Avatar
    I've actually done that twice recently.
    09-27-2017 10:42 PM
  7. B. Diddy's Avatar
    You wiped it after the update or before?
    09-27-2017 10:47 PM
  8. Abbers727's Avatar
    I cleaned / wiped the cache partition after the update.
    09-27-2017 11:34 PM
  1. Replies: 6
    Last Post: 10-11-2017, 06:57 PM
  2. Does J5 Prime have a private mode access?If not how can i secure my folders?
    By Shadrack Shaq Diphoko in forum Samsung Galaxy J Series
    Last Post: 09-26-2017, 04:29 PM
  3. My TMobile Note8 does not turn on!
    By Sammuel1973 in forum Samsung Galaxy Note 8
    Last Post: 09-21-2017, 07:04 PM
  4. Replies: 0
    Last Post: 09-20-2017, 09:03 PM
  5. Replies: 1
    Last Post: 09-20-2017, 06:00 PM
