1. dan911radio's Avatar
    Sometimes it Fast Charges...sometimes not...
    Using both the original and "just WIRELESS" fast chargers. It's the female with prongs that determines Fast Charging....as I have had problems with the original cord and others. Fast Charging is set to ON.
    Any ideas? Thank you
    09-26-2017 01:54 AM
  2. yarnsrj's Avatar
    Yeah.. Take a closer look at the pins on your charging cable. I believe the fast charger ones have 5 small pins, which over time will break. That's what happen with my OEM Samsung fast charger, I noticed one of the pins was missing. Once I purchased a replacement fast charge cable, fast charging for my Samsung Note 5 is working again. I just so happen to use same plug with my wireless charger, which also had issues until I bought the new charging cables. All work fine now.
    09-26-2017 06:24 AM
  3. dan911radio's Avatar
    I will...THANK YOU SO MUCH!
    09-27-2017 01:31 AM
  1. Trusted Voice: Say 'OK Google' to unlock phone - not working with AOD enabled
    By DLCPhototography in forum Samsung Galaxy Note 8
    Last Post: 05-17-2018, 10:29 PM
  2. Replies: 1
    Last Post: 09-29-2017, 01:10 PM
  3. USB C to USB C phone to phone charge?
    By kirksucks in forum Samsung Galaxy Note 8
    Last Post: 09-26-2017, 08:58 PM
  4. Replies: 0
    Last Post: 09-26-2017, 01:17 AM
  5. not able to see list of numbers grouped in contact in moto e4 plus
    By shalini5781 in forum Moto E4 & E4 Plus
    Last Post: 09-25-2017, 09:56 PM
