1. azjoan's Avatar
    I've had many android phones over the years, so last year when I switched to the Samsung S7 Edge I didn't expect any real issues with a learning curve. I've had several new apps, since this edition of the phone, and if you have to put in a birthdate, it doesn't allow you to pick a year and then separate month and date, it starts with a current calendar and you have to scroll backward through YEARS UPON YEARS of calendars. I'm 57 years old, I have to scroll through calendars all the way back to 1959, meaning I have to slide the calendar 684 times to get to my birthday. I've never had this issue with any other android phone. Anyone have ANY IDEAS on how to change this so that I don't have to wear out my finger scrolling backward for years?
    younggreenanne likes this.
    10-02-2017 10:17 PM
  2. Bosbouer's Avatar
    Tap and hold the year to highlight it. Then roll back the year. I regularly oveshoot 1945
    azjoan likes this.
    10-02-2017 11:38 PM
  3. chanchan05's Avatar
    You can flick it. You don't need to scroll slowly. I mean a single flick can scroll the thing like 30 years.
    Like this:
    10-03-2017 02:15 AM
  4. azjoan's Avatar
    I'll try that, next time!
    10-04-2017 08:08 PM
  5. azjoan's Avatar
    I don't have the option of scrolling through the years, I truly get a calendar and have to flick back 57 years times 12. It wears out the finger, and when I was doing this the other day I had made a mistake somewhere in the form and it made me start over, so not only did I flick 684 times, I had to do it TWICE!
    10-04-2017 08:09 PM
  6. chanchan05's Avatar
    Ok. That's weird. What software version are you on?
    Wait you said apps. I think that would depend on the app and not the phone.
    10-05-2017 03:51 AM
  7. lex63075's Avatar
    I'm finding this on a bunch of new apps and web pages on my s7 edge as well and it's infuriating! I'm over 40 why in God's name did they remove the option of toggling the year? The developers doing it should be flogged. I've deleted several apps for having it this way. If you kind people have a work around I'd be eternally grateful.
    I attached a screen shot of the offending dialog box. You can see no way to toggle the year.
    Attached Thumbnails Birthdate on Apps requires scrolling through YEARS of calendars-screenshot_20180119-113713.jpg
    01-19-2018 10:49 AM
  8. justin9999's Avatar
    Bump?
    08-08-2018 03:02 AM
  9. anthony2393089's Avatar
    I just figured out that if you click on the year it pulls up the years and you can scroll through the years quickly by flicking your finger quickly. Hope this helps.
    11-06-2018 05:58 PM
  10. anthony2393089's Avatar
    Wait, yours looks different then mine. I'm not sure what to do. Sorry
    11-06-2018 06:00 PM
  11. Trisha Gay's Avatar
    02-01-2019 03:39 PM
  12. Trisha Gay's Avatar
    OMG this is probably way late but I had same probly I've done it several times but I finally figured it out...GO UP TO THE YEAR IN THE CALENDAR AND CLICK IT LOL yeah that easy I tried clicking the date but never I guess JUST THE YEAR...I'm so happy I finally figured it out I feel pretty dumb but anyway hope you read this and it helps
    02-01-2019 03:42 PM
  13. lex63075's Avatar
    Some can, some cannot. Specifically, I was complaining about the app IBOTTA here. There is no way to toggle it on the phone. You can on a computer, which I ultimately used. Some, you can click on the year, some don't even display the year, others don't toggle no matter what you do the year.
    02-01-2019 07:37 PM
  1. Why will half of my music not show up in Google Play Music?
    Last Post: 10-03-2017, 12:28 PM
  2. Best smartphone. In budget of 11000
    Last Post: 10-03-2017, 05:02 AM
  3. Wherwhere are my incomplete drafts sent to on tracfone
    Last Post: 10-03-2017, 04:58 AM
  4. Replies: 1
    Last Post: 10-02-2017, 10:11 PM
  5. how to disable recent apps hardware key in xolo era marhmallow
    Last Post: 10-02-2017, 08:08 PM
