1. xthestonex's Avatar
    I had android 6 on my galaxy s7 edge and when the new version came out I didn't want to wait for the OTA update (since it would take several months to reach my country) so I updated using odin to nougat (G935FXXU1DPLT_G935FOXA1DPLT_BTU).
    Now my heart sensor doesn't work, my settings app is messed up : I have 2 device maintenance and 2 apps options I have an option called "service provider" description : GIGA LTE, KT twophone. clicking this crushes the app.
    My friend who also has galaxy s7 edge and bough it with nougat has way less settings and all of the settings make sense.
    And when I tried restoring with odin again to G935FXXU1DQE7_G935FOJK1DQD1_CEL it didn't fix anything.
    I just want to restore (like in iTunes) to the latest version my country has. I tried using smart switch but after it does preparing, nothing happens, it doesn't tell me to enter download mode.
    10-05-2017 08:13 AM
  2. xthestonex's Avatar
    Fixed by using a different PC, must be a windows 10 issue
    10-05-2017 10:30 AM
  3. anon(5719825)'s Avatar
    I can't even get SmartSwitch to work on my Mac and I can't even get SmartSwitch to install on my Surface Pro 3 in Windows 10. It gives some error and never starts the install.
    Glad you got yours working.
    10-05-2017 01:43 PM
  1. Ive deleted the answer a call icon an would like the link to get it back please
    Last Post: 10-06-2017, 01:01 AM
  2. i try to replace my 32GB SD card with another 32GB SD card and it did not work
    Last Post: 10-05-2017, 09:17 AM
  3. How can I get rid of my data protection pattern because I forgot it?
    Last Post: 10-05-2017, 09:15 AM
  4. can't hear my phone, music, etc with buds that came with it.
    Last Post: 10-05-2017, 08:21 AM
