1. Tammy Grace's Avatar
    I have a Samsung Galaxy S7 edge. On android 6.0.1 (and software G935FXXU1APDN/G935FTEL1APF2/G935FXXU1APDN) Every time I try to share something the app I'm sharing from crashes and says "Unfortunately Android system has stopped. I have ran in safe mode and it didn't happen there. I did a wipe of the cache partition in recovery mode. I also did a factory reset. Noting solved the problem strangely it doesn't crash when sharing from the gallery but it does crash with everything else.
    Please help.
    10-06-2017 05:27 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Since it doesn't happen in Safe Mode, then something you installed is probably causing the instability. Unfortunately, this means you probably have to uninstall apps one by one until the problem goes away, in order to pinpoint the cause.
    10-06-2017 11:31 AM
