A
Android Central Question
I was just looking through my Google play library and realized that I couldn't install a couple of apps that's fine whatever, but then I look at an app I had installed just the other day that is now not even compatible. Which then got me to look at my other apps and some of which aren't compatible anymore.
Two examples of some apps not being compatible are Clash Royale and Clash of Clans and it’s not just Supercell apps. (Both of which just had an update I was able to update one but now I can’t even find them but when I did I can’t do anything. If there any other apps that are the same it won’t show me)
My android version is 7.0. I don't recall an update being installed since atleast two months ago. I don't know what all I need to say about my model but I can post more info if and as needed. I've tried clearing Google play cache and reinstalling it neither worked.
