1. Seussi's Avatar
    A couple weeks ago i put my phone on my nightstand to charge and woke up the next morning to check the time only to find out it was flickering bright white.
    I have tried everything from reseting it, recovery mode.. you name it.
    It wasnt until just recently i found out that if my phone is under light that the flickering wont happen until the phone overheats. Kind of weird if you ask me but im guessing that the phone may have overheated and possibly damaged the sensor? If i try to use it at night the screen flickers bright white and i cant see my screen, but if i stand under a light source it works fine.
    Do you guys think its a broken lcd/proximity sensor and has anyone else had this issue
    10-17-2017 05:17 PM
  2. pontiac005's Avatar
    Call Samsung and troubleshoot.
    10-28-2017 11:07 PM
  1. S7 Edge Suddenly Not compatible with most of my apps. 10/17/2017
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 12-22-2017, 12:59 PM
  2. Replies: 25
    Last Post: 10-19-2017, 07:55 PM
  3. Samsung s6 edge Changing Notification For one Contact changes all instead
    Last Post: 10-17-2017, 05:17 PM
  4. S7 Edge won't get past boot
    Last Post: 10-17-2017, 04:50 PM
  5. S7 Edge Suddenly Not compatible with most of my apps. 10/17/2017
    Last Post: 10-17-2017, 03:49 PM
