    There is a temporary ago I decided to reinstall the stock ROM of my device via ODIN, since it was presenting some bugs. After doing the whole process since then my device claims unauthorized actions or it was root when trying to enter apps like Samsung Pay, SHealth and Secure Folder. Someone who has been through this?
    10-23-2017 11:33 AM
  2. Rukbat's Avatar
    It sounds as if you installed a ROM that had been rooted at one time or another. Get the ROM file from SamMobile Firmwares.
    10-23-2017 02:59 PM
  1. Replies: 13
    Last Post: 12-10-2017, 05:04 PM
  2. Samsung A5 cant be locked after Noughat update
    Last Post: 10-27-2017, 08:13 AM
  3. Pixel 2 (Small) Edge Gap Between Glass and Rim
    By ndonnine in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-24-2017, 06:26 AM
  4. Compare to Galaxy S7 Active?
    By IHateMyTreo in forum LG V30
    Last Post: 10-23-2017, 11:07 AM
  5. LG Nexus 4: Stuck on "Software Update" after factory reset
    Last Post: 10-23-2017, 03:52 AM
