1. lennie paz's Avatar
    I just installed Textra, and I'm trying to figure out if it has a pop up window when receiving a text. Right now, the only thing I get, is a notification in the notification bar at the top of my phone. Is there a way to get the pop up window when receiving a text?
    10-26-2017 09:46 AM
  2. jasonandrews25788's Avatar
    go to Settings > Customize Notifications and enable both options under heads-up floating notifications
    10-26-2017 10:25 AM
  3. lennie paz's Avatar
    Should I choose Android heads up, or Textra heads up?
    10-26-2017 10:32 AM
  4. chanchan05's Avatar
    Android popup is the one that is built into the OS and has a reply function.
    But it doesn't really matter which you choose since opening the notification opens the popup reply, and doesn't take you out of your current app.
    10-26-2017 10:49 AM
  1. Samsung cloud issues. Won't back up messages.
    By GavinGalaxy in forum Samsung Galaxy S8 & S8+
    Last Post: 02-26-2018, 12:18 PM
  2. How do i stop ads popping up full screen on my tablet
    Last Post: 10-26-2017, 02:54 PM
  3. Notification shade pull down app
    By Les Abbott in forum Ask a Question
    Last Post: 10-26-2017, 08:17 AM
  4. Notification shade pull down app
    Last Post: 10-26-2017, 02:13 AM
  5. Replies: 1
    Last Post: 10-26-2017, 01:58 AM
