1. Sylbee's Avatar
    I have owned an S7 Edge that I use as my everyday phone since August of 2016, so it is a little over a year old now. Probably 3 months ago I noticed that my rear camera always has these lines manifesting whenever I open the camera app. I thought that the rear lens might be cracked but there are no visible cracks either on the outer or inner lenses. These lines or cracks also seem to be perfectly straight and perpindicular to one another; this is also unlike any crack that I would normally expect. I am pretty ginger with the phone and have only ever dropped it a few times and all of them were low impact (the worst that I can think of was knocking the phone off of a 4-5 foot ledge onto carpet) plus it is always in a fairly solid case. The lines are only visible when using the rear camera. I don't take a ton of pictures so I honestly can't specify when exactly they started to appear.
    I would like to know what these lines are and what caused them, and also if there is a way to fix it. The camera still works and that is great, but the lines are really distracting and just overall it sucks to have them there. I will include an image taken just now; these lines seem exactly how they are now as they did when they started.
    Attached Thumbnails Camera Cracks/Lines - What are they?-1509834291901-2016849810.jpg
    11-04-2017 05:26 PM
  2. Dngrsone's Avatar
    It looks like you are missing a few pixels in the camera chip itself. Not much you can do about that.
    11-04-2017 07:34 PM
  1. What is wrong with this forum's server?
    By leerandall in forum Site Feedback & Help
    Last Post: 11-11-2017, 04:58 PM
  2. Replies: 4
    Last Post: 11-05-2017, 03:00 PM
  3. What is wrong with this forum's server?
    By leerandall in forum Samsung Galaxy Note 8
    Last Post: 11-04-2017, 02:24 PM
  4. Which monocular can work with the LG G6 dual camera?
    By Android Central Question in forum LG G6
    Last Post: 11-04-2017, 01:18 PM
  5. Which monocular can work with the LG G6 dual camera?
