1. SuperGuyRemix's Avatar
    It does this nowhere else in my entire house. Only in the basement, it goes black and reverts whatever app I was using back to that certain app's homepage. No other devices seem to do this. I have filed warranty and got a new phone, and the replacement has the same issue. Any help?
    11-08-2017 10:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you explain that a bit more in detail? So if you're using Facebook, for example -- the screen will go black, and then it'll go back to the your main feed, as if you were restarting the app again? Is there anything that's creating a strong RF field in your basement?
    Also, was your house built on top of an ancient Indian burial ground?
    thecomicbookandme likes this.
    11-12-2017 12:24 AM
  3. natehoy's Avatar
    I like where the theory of an RF or magnetic field is going with this. The burial ground, not so much. LOL!!!!
    Is it in a specific room or spot (including different rooms but only in proximity of a specific shared wall), or throughout the basement?
    Do you have any equipment that is starting or stopping at or near the time(s) it happens?
    Is this just in a specific application / set of applications or all applications?
    How often does it happen?
    Start "Game Mode" for an app and try locking out the BACK button when running that app and see if the problem goes away.
    B. Diddy likes this.
    11-13-2017 05:27 PM
  4. SuperGuyRemix's Avatar
    Yes, it does that. Like on Instagram, it'll go back to the home feed. On games, it'll reset whatever I was doing.
    11-21-2017 01:01 PM
  5. SuperGuyRemix's Avatar
    It happens about 3 times every minute. It usually glitches twice, and then stops for a little bit. And it doesn't happen when I'm on the basement stairs, it only happens when I am actually under the basement roof
    11-21-2017 01:02 PM
  1. Replies: 3
    Last Post: 12-30-2018, 07:38 PM
  2. What are the best Android apps to get in the Play Store?
    By Jkirkman44 in forum Android Apps
    Last Post: 08-18-2018, 03:10 PM
  3. Here you go, $399!
    By br77494 in forum Huawei Mate 9
    Last Post: 11-22-2017, 03:27 PM
  4. Replies: 2
    Last Post: 11-09-2017, 03:12 PM
  5. Why does my galaxy note 8 keep shutting off after inactivity
    Last Post: 11-09-2017, 06:38 AM
