1. Nikolasp97's Avatar
    Hello , so i have an s7 edge and i havent used it for about 6 months because it needed a new lcd. So when i took it to change it i asked to change the battery too. Its been 2 weeks now and the battery is charging by itself while its NOT plugged in ( the thunder on the battery icon is not there BUT the percentage is going up by itself) ITS not just this but the battery also does not drain ( instead of draining its charging) but listen this, on any percentage the battery does not go down but up ( normally its draining but the battery is not showing it) and when the battery runs out it just turns off.. so i see now 100% while it is maybe like 5% and in some time it just turns off without me knowing how much the actual percentage is.... please please help its been 2 weeks now i have tried everything from cleaning the port to letting it 2 days off but nothing fixed my problem...thanks
    11-09-2017 10:39 AM
  2. Fit24's Avatar
    Sounds like you need to go back to the place that changed your battery.
    11-11-2017 05:17 AM
  3. EndrieHelps's Avatar
    backup and do a hard reset, try to recalibrate the battery too by fully charging it and (try lol) to let it drain to 0. otherwise i would advice to get a new battery
    11-11-2017 05:45 AM
  1. wifi no longer turning on automatically
    By jskinvest in forum Google Pixel & Pixel XL
    Last Post: 10-17-2018, 02:26 AM
  2. Theme question on Note 8 (Batman Injustice)
    By Nitro211K in forum Samsung Galaxy Note 8
    Last Post: 02-01-2018, 05:11 PM
  3. Why are there so many problems on my Galaxy S7 since an update in September?
    Last Post: 11-09-2017, 11:06 PM
  4. Verizon Galaxy S8 Sound on Galaxy
    By bsteiny16 in forum Samsung Galaxy S8 & S8+
    Last Post: 11-09-2017, 04:09 PM
  5. Samsung Galaxy S7 Always on Display Problem
    Last Post: 11-09-2017, 12:01 PM
